Head Gasket Replacement
5.2K views 9 replies 2 participants last post by  SparkyMJ
#1 · (Edited)
hello, my ninja 300 2017 has been overheating about 30min into my rides, the temp light comes on so I pull over immediately to let it cool down and bring it back to my garage…
I changed the head gasket but I think I may have installed it wrong,
The Manuel is not very descriptive when it came to the head gasket, just says “place new head gasket on”
The old head gasket I pulled off seems to be stuck together like there was gasket maker inside of it, I can’t figure it out!
As this gasket is double layered, I’m wondering if there is any gasket maker that goes in between the gasket? Or is it just dry placement,
I burped the coolant system, and changed the oil. Oil level is correct, I checked gaskets, they looked good besides the head gasket,
coolant system seems to be correct, I torqued everything to spec, and in sequence and replaced most gaskets.
Discussion starter · #3 ·
T
Hey! Welcome to the forums!
I think I can help you here. I have replaced the head gasket on my 300 and other bikes as well, and so far I am (knock on wood) 100% on my head gaskets working after install.
I've got a lot to say, so sorry if I ramble.
Good thing you have the shop book, it is absolutely required for this operation. Also, good on you for taking matters into your own hands! Most folks give up if it's not an oil change or chain cleaning.
Can you tell us a bit more about the bike? I think there is some other info that might help us help you, and I am curious as to how you arrived at the conclusion you needed to replace the head gasket. How many miles on the bike? General history about it? How do you ride it? Stay on top of oil and coolant changes? Does it run okay? What kind of coolant and oil do you use? What was the proximate event to you deciding the bike needed a new head gasket? Did you see bubbles coming out the radiator cap with the engine running? Have you performed a sniffer test on the radiator to prove that combustion products are escaping into the radiator?
Unfortunately to say, unless you did those last few tests I just mentioned and they had positive results, your head gasket replacement was likely entirely unnecessary.
For what it's worth, I (nor anyone I have ever met) needed to actually replace the head gasket in their bike because the head gasket has failed. They are usually just replaced out of necessity due to the proximity of other repairs or work. For example, when I replaced the head gasket on my 300, I did it because it was part of another repair job. In my case, I had moderate blowby in my engine at around 40,000 miles. So in my piston and cylinder service I replaced the head gasket (and many others).
I quite firmly believe that in most cases, when a normal motorcyclist has overheating issues with their motorcycle, it is not due to the head gasket failing. 95% of the time, overheating is usually radiator/cap/coolant/thermostat/water pump related, or a leak in the cooling system. I say this too because you are right, the head gasket is indeed multi-layered. These are called MLS gaskets, due to their multi-layer steel construction. And the key takeaway about MLS gaskets is that they are basically the best type of gasket for cylinder heads, bar none. When installed correctly, they essentially last forever, and never leak, and may even retain a proper seal even if you overheated the engine and it warped the cylinder or head. They are quite fantastic.
In regards to how to install it, you are also right; the manual does not say very much, nor to really any manuals. You do quite simply 'put the gasket on' and then put the cylinder head on. But the part that the manual doesn't say is how clean the cylinder and cylinder head surfaces need to be. You need to remove every single tiny scrap of old gasket or debris off the mating surfaces. I went so far as to lap the surfaces with a flat surface and wet sand paper. If you put the head gasket on parts that didn't look basically new, it will have a very hard time sealing. And indeed there is no sealant or adhesives used in the application of a head gasket. Nothing on it, nothing in the layers, nothing. Dry.
I would also have recommended you remove the engine to do this work, it's really only the chain and 2 large bolts at the back and a bunch of electrical plugs if you've already got the head off. I would also recommend a valve clearance adjustment, and new gaskets all around for everything.
Here is a link to the thread I made when I did my engine maintenance, it may serve you well. It was a learning experience for me at the time, so some of your questions may be answered there preemptively.
If you do the engine rebuild right, you should be able to just pour coolant and oil in and it should just work. There is no malfunctions associated with a proper install. So if you're still having coolant issues after the work, you will probably need to do it again unfortunately.
Sorry to be the bringer of bad news. On the bright side, I will answer any questions you have and help you get this working if that's what you'd like! We are here to help!
Mine has 60,000 miles on the clock and runs like a champ, in fact I crashed it last week and I will fix it up and bring it to the track again this weekend. Awesome bikes.
I hope this helps. Seriously, read my other thread as much as you can, I essentially documented the whole process.
thanks for this I only changed it because a spark plug busted in the head and I needed a new head, so I figured while I was down there might as well changed the gaskets,
It’s not a hassle changing it lol! It’s just a motorcycle! I cannot take it with me when I leave this precious world! But I will one day get her running perfectly! I’ll upload some pictures of what else I can see,
I cleaned everything
before placing the gaskets
should be a perfect seal! Still getting overheating temp light! Lol
Discussion starter · #4 ·
Update
I have found 2 spots leaking coolant, first spot is the left hand side radiator hose leaking quite a bit, and than I found this platform on the head in picture also leaking
(the hose that’s attached to the nozzle on the piston head)
Hopefully this will fix the overheating, obviously losing coolant is not a good cause
I’ll update this page tonight when I get off work and take her for a ride.
Discussion starter · #7 ·
Mike, can you elaborate on how to clean the surface of the head at home? I may not have cleaned it enough..
Same with the surface of the head tho too right? Gotta make sure that looks brand new as well too ?
Discussion starter · #9 ·
Slapping my new red fairings on while I’m at it, haven’t taken the top off of the head yet, thinking about taking the head to a nearby shop,
should I bring the piston barrel too? Will they also flatten that and port the barrel?
