Hey fellas!
Figured I'd start a thread for this, move it if needed.
My '14 N300 with 40k+ miles, a lot of commuting, hard riding, track days, and some people learning on it needs some real love and care. It runs pretty good, it shifts a little crunchy, a bit of lash has developed in the trans/clutch, oil gets dirty quite fast, slowly burns oil, idles low when cold, and sometimes has trouble starting if you don't have the magic touch.
So I set out to remedy as much as I can on my own, and hopefully someone somewhere can learn a thing or two from my mistakes.
Really, the whole bike needs love, except the brakes. I recently put on steel lines, cleaned the calipers and pistons out perfectly, and that is awesome. Here's the plan:
Engine:
-Piston rings/hone
-Cylinder, cylinder head, and valve cover gasket replacement
-Valve clearance adjustment/shimming
-new spark plugs
-water jacket cleaning (suspect buildup)
-engine exterior/sprocket area cleaning
Maintenance if a need is found:
-new pistons
-valve seats
Bike:
-new Dunlop Q3+ tire set
-new right handlebar (bent from previous owner dropping)
-AGV standard length adjustable levers
-fork oil (maybe ohlins cartridge if I can be convinced to drop the cash)
-new DID VX3(?) X ring chain
-wheel bearing cleaning + grease packing
-airbox/filter element cleaning (super dirty...)
-radiator fin straightening + clean out soak
If needed/wanted:
-fresh water hoses/clamps
-woodcraft rearsets
-exhaust header cleaning/coating
-block off plates
I may also 3D print some pieces to fill missing chunks in my fairings from previous owner drops, and then wrap over the areas, but that is for the very end.
It's not gonna be cheap, and it will take me well over a month of constant work. I've never worked this deep on a motor that wasn't broken, so that is new to me, but I think I got a good grasp on how things work and how careful I need to be.
I am already working on this project, I have recently dropped the engine, and I am working on getting the cylinder head off. Everything is just super dirty, mostly on the outside of things. So half of my job will just be degreasing and cleaning the exterior of things.
I want her fresh and ready for my last Spring track season in Arizona, and so she'll be cleaned and ready to rip for another 40k miles after I move.
Here's a picture after dropping the motor, and a lot of swearing. Lol.
Cheers, enjoy the spring riding.
Engine:
-Piston rings/hone
-new spark plugs
-new pistons
-valve seats
Bike:
If needed/wanted:
-woodcraft rearsets
-block off plates
