You're generally going to see a slight performance loss with any slip-on over stock as the stock can has some extra restriction on it. Adding most aftermarket slip-ons will open up a small bit of airflow and reduce back pressure a little bit. Which is why you get the burbling and popping and even a real felt performance loss when you take some slip-ons and remove the baffle. You really need a tuner to correct the fueling for the reduced back pressure and get some of that slight loss in power back. With everything tuned properly for most slip-ons, you may see a .03 of a torque increase with the slip-on but the bigger thing is that you'll get some of the lost power back and reduce or eliminate backfiring during deceleration. Mainly, as said, the slip-on is there to reduce weight, get something that doesn't rust out, and generally looks and sounds better than the stock muffler. Asking which one is better is like walking into a concealed carry meeting and asking which piece is better. They all have their uses, pros and cons. It all comes down to what makes your pants tighter vs wallet happier.
