Replace stock parking bulb?
19K views 14 replies 5 participants last post by  cruizin
#1 ·
I have an led wedge light that I'd like to replace the stock parking bulb with, but I'm not sure how to remove the stock one? All fairings are off and I can see where the bulb enters the main headlight housing. Do I just pull from the back?
Sorry I'm on my phone otherwise I would post a photo. Thanks.
#2 ·
im my signature is a link to our diy sticky. in there is the owners manual in pdf, grab it and have a lookie, i think from memory there is 2 screws at the back of the bike you undo & the light assembly falls out
#5 ·
No worries! I looked through the forums and while I've seen other bikes with the parking corner bulbs replaced, the process to replace them was never detailed. It's probably because it is so easy that it doesn't need explanation (I was afraid to tug on the housing without knowing for sure if this was correct - which it is). Anyway, maybe this thread will help someone else out.
Here is a photo of what it looks like from the back. Again, I just used needle nose pliers and gently wiggled and pulled.
And here is the finished product (it's more white than blue in real life):
