GSX-R Shock Install Step-By-Step
4 reading
77K views 80 replies 32 participants last post by  SportBikeSteve
#1 · (Edited)
I started a new thread so this can all be in one place. This original thread is where much of this information came from: http://www.kawasakininja300.com/for...00.com/forum/12-ninja-300-appearance-modifications/885-gsx-r-shock-install.html
Parts needed:
  • 1 GSX-R 600/750 (2006-2007) Shock. Ebay probably easiest source($20-50).
  • 2 M12 120mm x 1.25 pitch Bolts. 8.8 grade or better suggested. I used part# 91180A723 from McMaster-Carr
  • 4 1/2" spacers. I used 1/2" aluminum spacers, part# 92510A364 from McMaster-Carr. You can also use 1/2" wide 9/16" nuts. They will fit over the M12 bolt.
Tools needed:
  • Torque Wrench
  • Rear Stand
  • Jack Stands
  • Stackable or adjustable Wood blocks\wedge or something to lift the rear tire as needed(I used an old shoe)
    • You'll need to be able to adjust the position of the rear tire a bit to get it so everything is easy to remove and slide back in place.
  • 1 Zip tie or some strong rubber bands.
  • 19mm socket
  • 14mm socket
  • 15/32" drill bit and drill.
  • Calipers for measuring shock clevis.
  • Protective gloves. Thin rubber ones give the best dexterity.
Preparation:
To prepare the GSX-R shock for install you need to do a few things.
1. Remove all unnecessary parts. It should look like the linked picture.
  • It may have a Clevis on top with a huge nut. Remove both.
  • It may have some linkage on the bottom, Remove.
2. Clean it off. It makes it easier to work with if it's not making your hands\gloves all dirty. You may want to paint the spring
3. Drill out the bottom Clevis holes and the top bushing using the 15/32" drill bit. Make sure you're using the right kind of drill bit for Aluminum\Metal. The old thread made this sound really quick and easy, but it took me at least a minute per hole.
  • If you have a bench vice, probably best to clamp the shock in there.
    • You can hold it down against a table. Just hold it tight so it doesn't move while drilling.
  • Do the top first. Try to be as centered as possible.
  • Do the bottom one side at a time.
    • Do each from the outside. Don't try to push the bit all the way through in one go.
    • Once each has been done separately, then run the drill bit all the way through.
  • Test fit the 120mm bolts you bought through the holes. The bolt should go smoothly through both bottom holes with no binding.
    • NOTE: These bolts are not used for these holes, but they are the same thickness as the ones that do go there.
4. Widening the clevis on the bottom of the shock is the hardest part.
  • It's hard to do this step right before removing the stock shock since you'll want to measure against the stock shock and test fit the new shock on the linkage once you get close. The stock shock is 3.28mm wide. The GSX-R shock is about 3.1mm wide.
  • You'll probably want to use some calipers to measure and compare.
  • I used a hand file to widen. I do not suggest this method. It's hard to do it right or really get a nice flat grind, but it does work. It also takes about an hour. If you want to use this route I suggest rough and fine files. Use the rough file to get almost there. Then the smooth file to get it all the way there.
  • Using a bench grinder is probably the best method. You need to remove about 1mm from each side.
  • A dremel is probably a bad idea here. Too hard to grind the large flat area you need to.
5. Using the appropriate screwdrivers and a 14mm socket reset all of the adjusters to stock position as noted in the attached manual page (attachment 1).
The manual appears to have a typo. I'm pretty sure my Red fix is correct.
6. You probably cannot reset the spring preload until it is installed on the bike. You may need a spanner wrench for this, but the stock ninja 300 spanner wrench might work. Or a hammer and a blunt punch.
Remove\Install Steps:
I've attached the relevant pages from the service manual (attachments 2 and 3), refer to that for pictures.
1. Lift Rear of bike using Rear Stand.
2. Squeeze the front brake slowly until it won't go any further and then zip-tie or bind the lever down. Once you lower the bike from the rear stand this keeps it from falling over. Don't skip this step.
Bonus: If you leave this on for 6-8 hours it helps firm up the front brake and gets any stubborn air of the lines.
3. Remove the rear hugger. 2 screws and 2 hex bolts.
4. Remove the lower fairings.
5. Loosen the two shock nuts using a 19mm socket. They are on tight, a breaker bar might be needed.
  • Top bolt is under the small flat round covers on frame.
  • Bottom bolt is on the triangular shaped linkage below the swingarm.
Don't remove anything yet, just break them loose. You shouldn't need to get a wrench or socket on the bolt to loosen the nut.
6. Loosen the two dog bone nuts here as well. You shouldn't need to get a wrench or socket on the bolt to loosen the nut.
7. You need to have the rear of the bike lifted without using the rear stand.
  • For those with non-stock rear sets you can use jack stands on the rear pegs.
  • For those with stock rear sets, you'll need to use something else. Kawasaki has a special jack attachment thing. Please let me know the best method here and I'll update this post.
  • You also need to keep the rear tire off the ground to ease removal and install. Put wood blocks(wedge) under rear tire so it won't drop when shock is removed.
8. Once everything is ready to be supported, lower it onto your preferred method and remove the rear stand.
Set the rear stand aside, but keep it nearby you may need it again soon.
9. Remove the dog bone nuts and bolts and remove the dog bones.
  • You will NOT be reusing the bolt, but you WILL reuse the nut if you got the right replacement bolts.(1.25 pitch)
  • Be careful about rubber rings and bushings down here. Keep them together and pushed into the linkage or install point.
  • With the correct rear tire height, these bolts should slide right out.
10. Removing the shock nuts and remove the bolts.
  • Do the bottom first. Then the top. The shock will drop to the ground, so have a hand on it when you remove the top bolt.
  • If you have trouble pulling the bolts out, adjust the amount the rear tire is lifted until it's easy to pull the bolts out.
    • You can lift the rear swingarm using the rear stand, adjust the blocks(shoe) until the height is right.
    • Once you get it right, they slide right out.
  • You will be reusing these Nuts and Bolts. Do not lose them.
  • You may find some little rubber rings from the top bushing. The ones at the top cannot be reused as the bushing sizes are different. They are too big for the GSX-R bushing. Maybe you can cut part of the ring and make them fit? I didn't use them.
  • If any bushings are rings come out at the bottom, reinstall them down there. This shouldn't happen if things are smooth to remove.
11. Cut off the little plastic flap from the Battery box. Shown in last attachment. A sawzell would make short work. I used a hand saw blade. A coarse blade cuts through there quickly. A dremel might work well here as well, especially if you want to sand it to make it look stock down there.
12. To install the new shock you first have to insert it into position.
  • I could not insert the new shock from the top. It just doesn't want to fit.
  • I installed it from the bottom.
    • To do this you need to lower the rear tire onto the ground to get maximum clearance from the swimgarm.
    • You can use rear stand to life the swingarm, remove blocks(shoe) and lower the tire again.
  • Work the remote chamber through the swingarm hole carefully and then you should be able to raise it into position. It takes a little fiddling. If you want to keep the new shock pretty, maybe put some masking tape on the top until it's all done then remove the tape.
  • You might be tempted to do the top bolt, don't do that.
  • Install the bottom of the shock into the linkage using the saved nut and bolt. Finger tight.
  • Let the shock rest on the swingarm with top bolt uninstalled.
13. Reinstall the dog bones onto swingarm.
  • You only want to install the top dogbone bolt for now. Let the dogbones hang lose. We'll do the lower one in step 15.
  • Use the new 120mm bolts and the spacers you bought.
  • It should be bolt head, dog bone, spacer, linkage, spacer, dog bone, nut.
  • If the bolts seem too short, it's probably because you bumped out the bushings, push everything back into place and they'll fit fine.
  • Again just finger tight for now.
14. Now finish the shock install by doing the top bolt.
  • You'll need to lift the rear wheel again. Probably a bit higher than you lifted it ever before. If the height is right, the bolt should slide right through.
  • Finger tight for now.
15. You can now finish the dogbone install for the dogbone to linkage. Follow same pattern and info as in step 13. You may need to adjust rear tire height again to get things lined up.
16. Now that everything is in place you can torque everything down
  • Torque all 4 bolts down to 44 lb\ft. (59 Nm)
  • These are lock nuts, you shouldn't need to use locktite, but you may want to put a little anti-sieze on the bolts.
  • The shock bolts should lock in fine without needing to keep a wrench or another socket on the bolt head.
  • The two new bolts will likely need a wrench on the bolt head to let you get them able to be torqued down. Once you get them tight enough you should be able to skip the wrench on the bolt head, just like the shock.
17. Reinstall rear hugger and lower fairings.
18. Lift back onto rear stand, remove jack stands or other lift method.
19. Remove zip-tie on front brake.
20. Lower bike back to ground.
21. Test compression by pushing on seat and sitting on seat. Make sure it feels fine before taking test ride.
* This information is provided with no warranty of any kind. Every effort has been made to make this information as accurate and safe as possible. Anyone attempting this modification is doing so at their own risk.
#62 ·
Spoke with Traxxion yesterday and decided to let them rebuild/revalve my GSXR shock for me. I already resprung my shock with an Eibach spring from Racetech so Traxxion will be installing replacing seals and o-rings, oil, nitrogen, polishing the shaft, and performing a full cleaning. Additionally, they will be changing the shim stack to get my desired damping curve. Somehow they verify the curve/tune it on the dyno but I dont know how that is done with out me there. Anyways, I am sending the shock to them this weekend and next week they are going to be calling to have a talk to go over how I want it to feel/perform. Their price was reasonable and I am excited to have a custom tuned shock.
#66 ·
I believe the clevis is 32.8 mm on the stock shock not 3.28mm it would be 3.28cm . The gsxr shock I measured to be 30.82 mm or 3.082cm. Am I correct or am I confused?
#69 · (Edited)
Finally got the chance to do this GSXR swap with the help of FreshFace! The instructions was pretty clear! The result was exactly what everyone mentioned; it feels super planted. My GSXR shock came stock with standard setting but for my weight, it was pretty stiff so I will need to be readjusting it. It's also a good idea to fix the front as it will nose dive. I have preload adjusters for my front forks so I stiffened the front up.
For those that want to tackle this mod, I say it is worth it!! Cost me ~40$ (30 for shock [ebay] and 10 for nuts/bolts/washers [homedepot]). I will post up some pictures. Most of the credit goes to Freshface for helping me out and sending me pictures of what to get and placement of the bolt. I will also try to do a shorter instruction version of what DeltaFoxtrotZulu wrote. He did a exceptionally good job with the details, don't get me wrong!
1. I suspended the bike using hooks and attached it to the roof (plywood), this allowed me to remove the necessary bolts holding the stock shock. The jack helped lift the bike up and I just kept it there for security measures. You will need to remove the bolt holding the TOP of the shock, the BOTTOM of the shock and finally the 2 linkage(?)(black piece with 2 bolts holding the top and bottom). This will completely free the stock-shock and expect the swingarm to drop. I suggest placing a or something to rest the wheel.
2. GSXR shock: For this, you will need to widen the top bushing with a 15/32 drill bit which I got from HomeDepot. (I ordered a shock off a 2007 750cc GSXR which worked perfectly). Make sure you get EXACTLY this tool because we tried using a rotary file thinking it will work but it messed the rotary file up. Then Widen the bottom clevis with what was mentioned on the first page. Then, the pain in the ass part, widen the inside clevis. File and widen the inside by exactly 1mm. Once that is done, you are ready to assemble!
3. Re-assemble: Have someone lift the swingarm back to the normal height, and slide the GSXR shock in from the top down into position. Assuming you already cut off the flap, it should fit very snug. You will use the same stock bolt for the TOP and the BOTTOM of the shock where you did the drilling. The new bolts will go into the black top and bottom of the linkage. Make sure you follow the diagram Freshface drew with the washers in that order. I used Loctite for extra precaution.
You are done!!
DISCLAIMER: I might of missed some minor information but most of it should be on the first page :) Happy Modding!! Feel free to PM me if you have any questions but preferably leave your questions on this thread in case others has the same questions :)
MODS: If you could move the attachments or these tips to the front page, that would be awesome!! Thanks
Reactions: howlinhoss
#71 ·
Yes indeed! Great job folks...my shock has been sitting here for a year now waiting for me to get around to doing this. I do want to have it rebuilt/serviced by Racetech first and have them install gold valves in the front end as well. Just an excuse for being lazy? You bet :biggrin:
Ordering some pre-load adjusters from SSR today...
#74 ·
Amazing post, definitely made this mod so much easier. It is definitely worth the time for such an inexpensive mod that totally changes the feel of the bike. I'm still trying to get the compression right, but I can feel more feedback than stock and with the new rearsets the bike feels a bit more responsive.
#75 · (Edited)
Here's a few interesting points concerning the nitrogen charge in the GSX shock:
1- I was able to get it recharged by a refrigiration technician as they use it to flush the lines before recharging a system with freon.
2- We charged the shock to about 150psi using the gauge/regulator on his tank.
3- Afterward, DO NOT, I repeat, DO NOT measure the pressure in the shock with a tire gauge: the quantity of nitrogen in the bladder is so small that each measure will lower pressure drastically. For example, the shock that was charged 90psi, dropped to 63psi in one single measure. It dropped down another 15 psi in the subsequent... then another 12... You get the idea.
4- You can see if the nitrogen charge is correct by pressing the shock against a weight scale. The weight needed in order to compress the shock (with spring removed) was around 40 lbs.
I'm in the process of installing my GSX-R shock; many thanks to all for all the precious infos! :emot-worship:
Pics...
This post has been deleted
#79 · (Edited)
The part description on my invoice from McMaster-Carr for part# 92510A364 is given as "Aluminum Unthreaded Spacer, 1" OD, 1/2" LG, for 5/8" Screw Size" -- they seem a bit... sloppy.
Curiously though when I searched for the spacers, there were two variants given: 5/8th screw size, and 1/2" screw size. I went with the exact part number, which yielded the 5/8th screw size. However, I would suspect the 1/2" probably fit a bit tighter, since an M12 bolt has a diameter of 0.4724 inches.
Guess I'll be placing yet another order... at ~$7each, US. :frown2:
