21 - 40 of 81 Posts
Discussion starter · #21 ·
The blue adjuster is a newer model. Might not fit right. I think 08-09.
That's a good idea on the foot pegs. Flip them so they won't fold. Smart. Glad this helped.
What kind of adjustment does this have compared to the stock rear shocks? The stock one lets you adjust from 1-5. What about this one?
Discussion starter · #23 ·
Look at the first attachment.
Where can i find these supplies to purchase in canada? the site that you got them from emailed me saying they cannot ship to canada.
They don't carry the spacers, got a suggestion for those? I asked about the 1/2" wide nut too but he said he doesn't have @ metricspecialties.
Discussion starter · #34 · (Edited)
Thickness: 0.484"
I think that's pretty standard. Should be fine. Worst case add a washer to both sides if it's a little too thin. The main issue is making sure dogbones don't touch the spring.
Here's another possible choice: Amazon Product Page
Change the Inside Diameter to 0.505. Length to 1/2. Should show you product code: B009YLMID8 (Can't link directly to this apparently)
Or you might find them on eBay.
Discussion starter · #36 ·
Even with no preload the spring is under plenty of pressure. You need spring clamps to remove it I'm pretty sure.
Most forums I've ran across people have gotten away with masking off the shock and painting the spring while it's still installed.
Yeah man don't try to take the spring off without a spring compressor... bad juju. Even the cheap ones for DIYers are kinda sketchy but better than nothing.
DFZ thanks again for this write up. It really helped. I widened the clevis, drilled the holes, and am am in the process of painting the spring. Once I get my bike back from the shop I will be checking my widening job and installing the gsxr shock. Hopefully that part goes as smoothly as the rest.
21 - 40 of 81 Posts
