Are there any connections that u can just unplug for the number plate light? Or is it a must cut??
Already said. Not sure if you can use the regular license plate light with the Yoshi kit, but I highly doubt it would fit / line up nicely with the plate holder on the new kit.The LED wires require cutting off your stock license plate light wire and reconnecting to the yoshi LED wires.
Should we follow the Targa FE guide on here for removing panels? Or do we have to remove less for this kit?I like mine a lot. The yoshimura aluminum led light thing is very cool looking. The bracket feels very solid once installed. I didn't like splice things they give you so I went and bought something better, easier to use. Otherwise went great. Just make sure to remove panels in the right order.
Not sure where that guide is. I just learned the hard way everything starts with the little panel under the seat. Once that is off, you can remove the seat. Then you can remove the bolts necessary to remove the rear-side panels and the panel under the rear of the seat. As it turns out probably didn't need to remove much panels at all, but it does makes things easier.Should we follow the Targa FE guide on here for removing panels? Or do we have to remove less for this kit?
