Yoshimura FAIL rear set brackets/shift rod
9934 Views 26 Replies 11 Participants Last post by  Aussie117
2
Planning to get rear set brackets from Yoshimura for your Ninja 300?
KOOL!
Just don't get it from Yoshimura...
I ordered their Yoshimura rearset bracket kit for my Ninja 300. At the time of installation, everything went fine till the point I needed to replace my stock shift rod with the one provided with the kit.
IT DOESN'T FIT! THREADING TOO BIG! (insert joke)
Some of you know what I'm talking about. For those who ordered it and tried to install it..then found out the shiftrod doesn't fit...I got the same response as you did from Yoshimura.
"It's the correct part, it fits on our R&D bike."
"The rod had reverse threads, try putting it on the other way"
etc. etc
I won't make this a long rant about their rearset product. For some people the shift rod fit, for most people including myself, it didn't. Could be because its a new bike, but if its almost identical to the 250, there shouldnt be a problem
If it fit on correctly, the bolts don't have to be forced to spin on the rod threads or the rod arms attatched to the bike. It should be an easy twist on twist off like a bottle cap
Save up a bit and get more high quality rear sets...but if you want to give it a shot and settle on Yoshi's, go ahead.
I just wish someone did more reviews about it not working
***Refer to the 3rd page of the thread to read a positive outcome to a negative situation :D***
21 - 27 of 27 Posts
4
First off, I wanna thank Doug Wells from Yoshimura for taking the time to contact me and work with me on the Yoshimura Ninja 300 rear set kit's shift rod problem. The guy is really patient and helpful, and for that I'm much appreciative. He also was kind to send me a Yoshi hat, water bottle, two Yoshimura muffler keychains, and of course most important a shift rod that fits with the kit! It seems like all this back and forth with Yoshimura influenced them to test their parts on a new Ninja 300 that was not their orginal R&D bike. It seems there was a legitimate problem with the fitting of their Ninja 300 rear set kit. HOPEFULLY to all those who have purchased or will purchase this set will not run into the same problem I have, but if so, they now have a replacement shiftrod to correct it.
As for the kit itself, its everything I expected it to be....awesome! I'm 5'6" with fairly long legs in proportion to my body. Although rear sets make most people feel "cramped" on their bike, I welcome the new riding position. It helps me keep an aggressive body position and allows my legs to do more "suspension" work on bumpy roads and better grip on the tank with my thighs. Also, for me the kit helped me become inspired with confidence while taking corners since my feet and pegs are farther from the ground than the original stock position.
Aside from the mix-up with the shift rod size, all in all it was a great rear set product aside from replacing the whole rearset for aftermarket ones.
In the kit's instructions, it said I would need to cut the tube running from the rear break reservoir to make the brake side rear set fit. I didn't want to cut anything, so I just pushed it back a bit, and it works just fine. Whether or not this is a good idea, it hasn't caused any problems so far.
AND, Thnx spacep0d for giving your buddy at Yoshi a shout out of my thread..much appreciated!
Reactions: 1
First off, I wanna thank Doug Wells from Yoshimura for taking the time to contact me and work with me on the Yoshimura Ninja 300 rear set kit's shift rod problem. The guy is really patient and helpful, and for that I'm much appreciative. He also was kind to send me a Yoshi hat, water bottle, two Yoshimura muffler key-chains, and of course most important a shift rod that fits with the kit! It seems like all this back and forth with Yoshimura influenced them to test their parts on a new Ninja 300 that was not their original R&D bike. It seems there was a legitimate problem with the fitting of their Ninja 300 rear set kit. HOPEFULLY to all those who have purchased or will purchase this set will not run into the same problem I have, but if so, they now have a replacement shift-rod to correct it.
this is awesome customer service. well done Yoshi for stepping up, taking ownership of the issue & sorting it out
Reactions: 2
You have to cut what!?
I have these on the way but I never knew I was supposedly going to need to cut anything. :/
I never cut my brake resevoir tube either, just made sure it coiled around and not kink up.
Yeah Doug is great! Glad they got in touch with you and made it right! :)
Reactions: 1
Since the kit lifts back/up your stock rear sets, the tubes connecting to your brake side rear set is pushed back. Instructions in the kit suggest to cut the tubes but you can (at least I did..) push them back a bit. It'll be easier to see what I mean when you get your kit in :p
PLUS, if you decide you really don't like the modification, you can set them back to stock and not have to get new tubes
I had Problems Guys with the eBay (Repeat posting to ensure others are Edulated)
The Supplied product was actually very impressive.
Brake Switch that others have posted about didn't pose an immediate problem as the existing bracket was catered for and was simply reattached. I will re comment about this in future one the job is complete.
HOWEVER
The Shift Rod connector had the wrong threading. Now there is a similar "Forum Thread" about the Yoshimira sets having the same issue.
<<<< System didnt allow me to Add the Link"""
I have contacted the Ebay Supplier and am waiting a response.
In the Meantime.... I would love an idea of how to proceed.
21 - 27 of 27 Posts
