GOT A FEW IN
http://www.biohazardcycles.com/servlet/the-6493/YOSHIMURA-040BG147000--BLACK/Detail
YOSHIMURA 040BG147000 NINJA 300 CHASSIS FRAME PROTECTOR KIT 300R 13 2013 PRE ORDER TO SHIP MID FEBRUARY
YOSHIMURA 040BG147000 BLACK FRAME / CHASSIS PROTECTOR KIT
KAWASAKI NINJA 300R 300 ZX-300R EX300
13 2013
Yoshimura Chassis Protectors help minimize damage from sliding type falls, can save you hundreds of dollars in repairs, and maybe keep you from getting a DNF on race day. The plastic construction is soft enough to slow slides and wear down slowly... yet tough enough to keep the track away from your bike in most cases.
These Chassis Protectors are specifically engineered for the Ninja 300. Brackets are bolted to key structural areas behind the fairing, tieing into the upper and lower engine mounts. These provided stout mounting positions for the chassis protectors through the fairings.
Price: $152.56
No. Part # Description Qty
1 040BG147000L Left Chassis Protector Bracket 1
2 040BG147000R Right Chassis Protector Bracket 1
3 1104-A02-00 Chassis Protector Spacer 2
4 040BG-MS Chassis Protector 2
5 040BG-MSI-10 Aluminum Insert 2
6 M10X80 10mm x 80mm Socket Head Cap Screw 2
7 M10X1.5X220 10mm x 1.5 x 220mm Hex Head Bolt 1
8 10X20WSH 10mm Washer 1
9 10MMX1.5FNUT 10mm Flange Nut 1
** 17020C Yoshimura Sticker Sheet 2
13 2013
- Sold as a Pair
- Welded, powder-coated mounting brackets
- Laser-etched Yoshimura logo on Inner Sleeve
- Includes necessary hardware and detailed installation instructions
- Fairing cutting/trimming templates are included
Price: $152.56
