1 - 3 of 3 Posts
What is the color of white is on the 2017 ninja 300. I have the white and black with ABS. It's a super super white color but has a little shimmer to it ..
Tire Wheel Vehicle Fuel tank Automotive fuel system
I don't know for sure, but most likely it's a Pearl White. Possibly a white base coat with a pearl clearcoat or a white/pearl base with a standard clearcoat.
ColorRite is the only place I've seen that offers matching paint for cycles, but it's expensive and may not match that well. Any type of touch-up will be noticeable with this, or any metallic, type of paint.
@jkv45 is close - it's Pearl White Blizzard, the Kawasaki color code is 54X. You need a base coat and a top coat, in addition to the clear coat to match the finish.
From ColorRite, you need the following:
You can try to touch it up yourself, but it will most likely end up looking worse than when you started. I suggest either getting it done by a professional body shop, who will paint the entire fairing or tank. If it's just a fairing, it will likely be less expensive to simply buy a new one.
1 - 3 of 3 Posts
