as the title says...noticed a slight leak under my water pump when I did my end of season oil change in November. I thought I traced it to the pump cover gasket so ordered new gasket and 2 O rings for the metal water pipes. Spent 4 hours today removing the fairings and drained coolant, pulled gasket cover, replaced gasket and O rings, re filled with coolant. Placed a white paper towel under the water pump to check for leaks and I'll be damned if I didn't see 4 or 5 drops on it after running the bike for about 10 minutes.
Even though I wished really, really hard that it was just leftover coolant from the change that somehow dripped out...I don't think so. It seemed to be coming from where the water pump connects to the motor. I think the only other items to replace are the mechanical water seal and the O ring (and I keep hearing @SparkyMJ saying recently that as long as you're in there you might as well replace everything).
So now I'm thinking if I do this I probably need to order another new water pump gasket and O rings plus mechanical seal and o ring..crap...or I just take tit to the dealer since I need a new chain, sprockets and tires, anyway. (hate to think how many weeks THAT will take to get done...).
Attached pic shows bottom of water pump. Yellow line is where pump cover meets water pump and where I replaced the gasket. Circled area in red is where the coolant appeared to be dripping from. Am I correct in thinking it's likely the mechanical seal? (no coolant in my engine oil..just leaking out)
