I'm trying to install the Scottoiler VSystem but I have no idea how to remove the vacuum tube connection. I'm not entirely sure I'm even looking at the right part honestly. Really could use some help so I don't do something stupid.
From the right side of the bike, is it that sucker I'm supposed to take off? I'm assuming that's the throttle body, but I'm also terrible at figuring out what the service manual is showing. Excuse the green light I used
Aite, and that's why I ask before doing anything drastic. I think this may have to wait until next weekend now. I have no idea where the intake is either. I've never really done much beyond oil changes on a bike.
I can remove the fairings. Is it possible to remove the gas tank without draining it? I don't think I have the means to do that. Short of going to a mechanic, I'm pretty much on my own for this.
If you get down to the bare tank, remove the 2 rear bolts and you can lift the rear up and prop it on a scrap of 1X4 wood. Don't pull it so hard up that you stress the hoses/wires.
Then you can probably sneak in and get it done, but be sure you have a vac line before cutting! CB might have a pic handy, he was in there messing around recently.
Does the vac line absolutely have to cut on the 300? Their site actually has instructions for a FI Ninja 250R and, assuming the 300 isn't too different from that, they say to just remove the rubber bung, then put the L-shaped rubber piece on the spigot. I have also heard it's a pain to remove the rubber bung though.
I have no idea what you have in the kit. Sounds like that should work, I believe the Euro/Asia 250 is identical to our 300 but a few bits could be different. Worst cae you need to add in a T or Y.
The kit comes with pretty much all the connections for any possiblity so I could cut it. I just figure if I need to go back to stock for some reason then not cutting would be better. I may end up cutting anyway if getting the rubber bung off proves to be too much of a pain in the ass.
I'd not be too worried, if you splice in a T you can always cap it later. Not a big deal, look for the easiest access and shortest route and go that way.
can can add a line directly off the throttle body, which does have a little rubber cap on it, dont splice into the line with the intake pressure sensor on it..
1 - 17 of 17 Posts
A forum community dedicated to Kawasaki Ninja 300 motorcycle owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, and more!
