1 - 2 of 2 Posts
2015 300 ABS
Wondering if anyone can help me ID these aftermarket fork valves (or are they emulators?). Hoping they might be recognizable to anyone who may have upgraded the stock forks. I can’t find anything online that look exactly like these.
These valves were found when I removed the forks to rebuild them. They sit on top of the fork damper rod, held in place only by the o-ring press fit into the top of the damper.
Also, the damper rods have had the small holes at the top filled in, and new larger through holes (9/64th?) drilled closer to the bottom - about 90° apart from each other.
Any help is appreciated. Pics below.
Gas Auto part Engineering Metal Nickel
Household hardware Auto part Metal Nickel Engineering
Office supplies Material property Wood Gas Auto part
Dead bolt Gas Circle Button Metal
1 - 2 of 2 Posts
