Went to ride home from work late last night. Started my bike, done all my usual pre riding checks..brake lights, indicators etc...left indicators are both working fine, but my right indicator the front one turns on and stays solid and the right does not light up at all, the indicator light on the dash also stays light up. Back to the dealership, ill let them figure it out while im still under warranty.
Check your right rear indicator bulb. It is more than likely blown.
Most cars and bikes have a simple circuit in the electronics to either flash the indicators faster, or not at all when you have a blown bulb. My car is the same, when my right front indicator goes (which it does very frequently) the right rear does not flash and the indicator light on the dash stays illuminated.
Its simply an easy way for the vehicle to give input back to the operator when something is not right. This is why when people put the LED indicators in, they either have a fast flash rate or do not flash at all, as there is not enough power drawn by the LED to register to the electrical circuit that something is drawing a current. So in the electrical circuits opinion, something is blown and you get the resulting fast or no flash until a replacement flasher unit that can pickup on the load is installed. Not saying you have LED indicators, just an example to further the point.
Check the bulb of the indicator that is not flashing. You more than likely have a blown bulb or fuse that corresponds to that bulb/side.
My bet is on the blown bulb........
