1 - 20 of 22 Posts
My bike seems to have developed a strange whine when accelerating in 4th, 5th or 6th gear. It isn't terrible sounding and honestly if it had always done it I would accept is as normal noise. just strange that it started out of the blue one day and now in addition to the engine/exhaust noise while accelerating you get an extra whining noise that almost sounds like tire noise on a car when your going down the highway. I'm not talking about the whine it makes when at low rpms and letting the clutch out this is different and only happens like I said in 4th gear and up.
I've ruled out everything else it could be like chain/sprockets, tires etc. It's def. the transmission, just not sure if it's an issue and if anyone else experienced this?
Motorcycle gears are noisy (whiny) by default because majority are straight cut vs helical for cars. Degradation of oil (thinner) can cause noise increase at high velocity. How many miles on that bike ?
Oh yeah I know the sound. My bike has always had the typical whine from the straight cut gears. This is an extra noise (high pitch whine) that is most noticable in 4th gear around 40mph (beyond that the wind and exhaust noise wins). I’ve done everything I can do for now it’s got fresh oil and filter in it. Until something goes wrong I can only treat it as normal transmission noise. It isn’t even a “bad” noise it’s hard to describe but if it had always been there I wouldn’t have thought twice about it. Maybe it is normal and I never noticed it before….
Just passed 10,000 miles.
Maybe something to help you find the issue,,, I would jack the bike with a proper center stand and strap it for safety, put it in 4,5,6th gear and give it some gas slowly and carefully to be double sure where the noise is coming from.
Also If you didn't see anything weird with the oil change like shavings ... I'd be less worried for now.
Discussion Starter · #5 ·
Yeah I’m not too concerned with it though the guy I bought it from had dropped the bike and in the process he bent the shift lever. On top of that O have always HATED the way this bike ahofts and have complained about it in the past. I have put 1,000’s of miles on it and still I can’t get smooth shifts. I’ve had Ninja 250’s a 500 and a 600 and have NEVER had a problem using the clutch and getting smooth upshifts and downshifts. Even when I was a noob 10+ years ago. Not sure if it is the slipper clutch or maybe something has been slightly wonky in the transmission all along but it wouldn’t be the end of the world if it imploded and forced mw to buy a new bike…. Maybe next year the Zx4R will be in the US and I can get one cheap from someone who made an impulse buy🫣
Does it happen through all the RPM's range? Sometimes I feel it kind of clunky in low RPM's, but smooth from mid to high.
Does the sound change when you pull in the clutch?
How tight is your chain? A tight chain isn't good, and can make odd noises.
Be sure to check it with the wheel in at least 4 different locations, as the tension will change. Set the proper tension at the tightest spot.
What oil are you using?
Discussion Starter · #9 ·
Thats what mine does but knowing when to pull the clutch in and let it out to get a perfect shift has been impossible for me to get used to with this bike for whatever reason. So much that every time I shift I have to wonder whether or not it will be smooth lol. A small thing but very annoying and I have never had to put any thought into shifting before this bike.
Discussion Starter · #10 ·
Jkv, do you mean does the sound change when I pull in the clutch when I'm moving down the road? Yes it does, that's what convinced me it is the transmission and not tires/chain etc. I tried coasting downhill at 40mph by pulling in the clutch and the noise goes away. My guess it has to be clutch/transmission related. I also have tried to get the clutch to slip to see if that needs replacing but it doesn't slip at all...
Fwiw I just put new chain and sprockets on as well (DID Vx-3) and it is adjusted perfectly with 25mm of slack. Also worth mentioning is one day I was riding around in town and it was very hot out and it started making the noise out of the blue. I figured at the time it was just because the engine was getting pretty hot but it has made the noise ever since,
I'm using Maxima Pro Plus 10-40 with an oem oil filter. Same oil and filter I put on the bike 6000 miles ago when I bought it. I changed it again about 1,000 miles ago...
Discussion Starter · #11 ·
I wish there was a way for me to capture the sound but it would be impossible. Tried quickly running it on stands to hear it but why won't it let you shift to second and up if the bikes not moving? I do like the neutral feature that lets you instantly shift into neutral when you stop but all the other trickery can take a hike haha😁
Not sure what would create the sound, but I would try a different oil next oil change. It would be odd that it would make a difference, but it would be worth a try.
I like Mobil 1 4T 10W-40. Shifts beautifully in my SV, unlike some other oils I've used.
Discussion Starter · #14 ·
Do you use the synthetic? I’ll try that. I may end up doing another oil change just to make double sure it looks okay since the noise started maybe 200 miles after the last oil change.
I use synthetic in everything.
Mobil 1 4T 10W-40 is full synthetic.
Mobil 1 oil filters are very good as well, and you should be able to cross-reference from the Kawi part number.
Discussion Starter · #16 ·
With the bike on the stand, you should be able to through the gears. I've done it in mine. Make sure you go from N to 1st, then 2nd and so on.
I tried but I think I need to have the rear wheel turning to shift from 1st to 2nd and up? Grabbed some Mobil 1 and a K N filter. Hopefully there arent any monsters in the oil when I drain it but 50 doll hairs for peace of mind is worth it. I only wish it had gotten noisy just BEFORE I did the last oil change lol.
On many bikes ,,, if not 100% ... there is a neutral finder unless the wheel is moving a little, it would be hard to go to second gear.
Like I said ,,,you can use the rear stand and start the engine from neutral,, work your way up in gears while on IDLE using the clutch (DO NOT REV risk off slipping of the stand)
If you have difficulty switching gears ,,, could be clutch out of adjustment or bent fork from previous owner
Hopefully it's not the oil. I also use the Maxima Pro Plus (Synthetic). But it never hurts to change the oil.
Yes, like @ELCouz said, keep the wheel spinning without revving it up so you don't risk it coming off the stand.
Discussion Starter · #19 ·
Yeah I dont think its the oil as I have been using Maxima Pro Plus in my bikes for a while and the 300 never had an issue with it before. Also changed to the Mobil 1 4t synthetic and no real difference. The noise still seems to be there. The old oil looked fine (and didn’t smell like burnt clutch plates) so there isn’t much more I can do. Just gotta get going quickly every time so the wind noise drowns it out haha!
Seriously though, I think it may be something to do with the clutch but either way I don’t think it is anything to panic about. I noticed when the bike is running warm on a hot day, when I put the bike in 1st it’s quite noisy until I let the clutch out to take off. I’m just gonna send it for now.
Discussion Starter · #20 ·
Maybe it gas to do with the clutch starting to wear out. It had 4000 miles on it when I bought it from a new rider. He dropped it after not owning it long and It scared him so he just wanted it gone.
I’ve never ruined a clutch but who knows how he got along with it lol
1 - 20 of 22 Posts
