This looks like the route I'm going to go for the sake of simplicity.
http://www.3brpowersports.com/TAPP_lite.htm
http://www.jpcycles.com/product/362-061
Question - Correct me if I'm wrong, but I shouldn't need an on/off switch because this would only draw power when something is plugged in, right? There's should be no standby power drawing to drain my battery.
Thanks in advance!
EDIT: Looks like it standby draws 8mA (.008A).... Would you guys wire it to a switch of its own, to another accessory.... or just leave it be because it's a small amount.. Thanks.
EDIT: Would wiring it to the taillight circuit instead of directly to the battery work?
Thanks in advance!
