1 - 20 of 30 Posts
Anyone know where to get a kawi green steering bstem nut , Or should I paint the existing one. Any ideas ?
most are painting it. R&G has a black cap, not sure if they have any other color. I my just hit mine with etching primer then black paint. (cheaper than Plasti dip here) :)
If you search for ninja 300 steering nut on amazon, there is a company called ssr motorsports that sells the nut in like 5 different colors. not sure of the quality, but theyre only $25, so it might be worth a try :)
Green really isn't going to be a widely available color for bike parts. I personally would get stuff powder-coated if I had the money. Might be able to color match better too.
Or you could go to the SSR website directly. ;)
They dont do green though, only black, gold, red, blue and silver. Send them an email they may be able to do you one in green. Or alternatively, buy a silver one and get it anodized green locally once you get it.
sadly, SSR uses cheap anodizing so expect it to fade if it sees alot of sun.
bewared painting stuff on your motorcycle
the sun will fade it & look like crap if not done right.
and if you wish to paint something & then clear coat it, make sure the clear coat is UV resistant or it will turn yellow, crack & peel off & like like crap in under 2 years
Discussion Starter #9
Thanks great advice . I ordered paint straight from Kawi so the match should be right on they are sending me a clear coat that they also use on their bikes so I figure if I prime first it should last. What do you think ?
I'd be more worried about a wrench/socket touching it after paint.
Plasti-dip would've worked better since it's easy to apply and remove.
Which is why I said to obtain a silver one and get it anodized locally. ;)
ANY anodizing will fade in the sun guys. Some last shorter than others yes.
about 13 years ago i went crazy with my vfr800. the rear wheel nuts, all 4 of them i got them 15 carat gold plated
to put them on/off you put a rag over it first then use a socket.no dramas at all, im willing to be the same thing here
I would just take off a bunch of stuff like rear pegs, and anything else you would want black and just hit a local powder coating place and get it done the correct way.
Discussion Starter #16
Only thing is I dont want blaxk I want green . Cam they match the color ?
If you would be willing to ship the nut or anything else depending if its small or whichever size to one of my friends who own a powder coating company I could let you know some more details. It's called Vagwerks they do Volkswagen and Audi wheels and engine parts etc. The website is here to show its official http://www.vagwerksperformanceandcoating.com/
Discussion Starter #20
What do you think the average cost would be . How do they calculate it ? Area, weight? I have a lot I want done rims , stock exhaust , wheel hugger .
1 - 20 of 30 Posts
