I was riding to work and it started and ran perfect. On the last few blocks it started chocking. I could full throttle it, but it would stay around 2k then it would suddenly get fuel. After work I started it up but it wouldn't stay on unless I kept giving it fuel. Also it would stall when I would stop.
Took everything apart. Put in new spark plugs, air filter, cleaned anything. I checked the pump and it was spraying out fuel, spark plugs were working, and the air filter is out so it should be the problem. Still didn't start. I then ordered a new fuel motor and filter. Still would not start. Got a mechanic to take a look to see if it was a fuel pressure issue. He said both pumps are broken... Go figure. Ordered a NEW pump. This one is much more expensive, but it will be here in the week. STILL WOULDN'T START. So less likely I have another bad pump. More likely something else is wrong. I'm thinking the fuel injectors because when I tried to start the bike it was trying to turn over so I checked if the spark plugs are getting fuel and they were not. We put in some ignition into the valves and it started. Also this bike has not been crashed but did tip over once about 6months ago so that shouldn't be the issue.
Thanks!
Thanks!
