21 - 40 of 59 Posts
$30 for an anodized closed nut is a little expensive for my taste, especially when the finish doesn't match.
I'm in the same position. I don't like the silver nut, but for $30 I'll pass for now.
So use a 30lb torque and use that to unscrew stock and screw on new? Also did you put locktight with the new stem?
Did you guys use loctite when installing the new stem?
yeah everything just blends better with black, now i just gotta try and paint that gas tank cap ;)
The longest part of doing that for me was taping up the parts I didn't want painted like the actual centre parts, I only wanted the surround black. Just do light coats though, otherwise the paint very quickly fills in between the ribbed areas on the surround, and then it looks pretty shit. I put it on too thick the first time, and then did it again with very light coats. Now it looks mint. :D
I am thinking of Red for accent. I have the Green SE and there is a bit of red on the decal. not to mention the RED kill switch.
What do you guys think... Red Tree nut, Green adjustable levers with RED adjuster accent, and Red Oil cap. Thoughts?
21 - 40 of 59 Posts
