1 - 4 of 4 Posts
My 300 hase done just 360km (180miles) an i am hearing sound for my chain i have lubed ot two times (One from the service center and one personally) to rectify the sound but in just 5mins after the lube it will start making sound. I checked the alignment of tire but its is okay. Does anyone have this issue? Service center just tells that it is a common thing for 300, is it? The sound is so annoying, it suppress all the other sounds.
Most likely the chain is too tight or has a seized link.
Check the slack every 1/4-turn of the wheel to see if there is a tight spot.
Always set the proper chain slack at the TIGHTEST spot.
jkv45....you mean to always set the chain tension at the Tightest point..right?..typo?
Reactions: jkv45
1 - 4 of 4 Posts
