1 - 20 of 30 Posts
that was the first thing I did. I got the silver star ultra. it takes the h7 bulb. I put those in everything I've got
I need to pick me up a set of those. The stock lights suck. H7 is our bulb size
Yep h7 is it . The bad parts is unless you take the plastic off it's very hard to change. I went ahead and took all the fairings off and took the headlight assembly off just so I knew how it all went.I got mine at Walmart
yea im getting them.i couldn't see 5 ft in front of me the other morning.im an older guy and cant see like i used too.It looks like maybe you could change um without taking the fairings off.i hope
H7 SU 2 is the part number i see on package at advance.48$ .OMG.I guess im going to check out flebay
Had the Silver Star Ultras. Swapped them for a set of Philips Ultra Crystal Visions.
I still have the old Silver Stars. They have about 3 hours of use on them. Want them? They're yours.
Discussion Starter #8
so are the Philips Ultra Crystal Visions that much better?
Personally...yes. I noticed a dramatic difference. Whiter, wider and further beam. Better vision at night time.
Reactions: old_rider
asimple headlight upgrade like this is well worth it if you dont want to go the HID route.
the benefit of doing this is bulbs are cheap and plentiful
i did a HID upgrade some years ago on my K1200LTSE and OMFG!!! what a difference , mind you the stock bulb was so dull i almost had to strike a match to see if it was going or not, but WOW what a difference in light.
Just installed my crystal visions. Kind of a pain in the ass if you don't take off the fairings but can be done. Theres a vid of a guy that does it on his '08 250 which i referred to. The rubber casing is a little different but pretty straight foreward
for the Aussies out there contemplating this, i have used "narva + 30" bulbs some years ago and they worked a treat, i see now thay have about half a dozen different types of the "plus" series
usually pick them up at supercheap auto and the likes
Discussion Starter #15
ok i did a little more research and found these.
Diamondvision 5000K h7.anybody tried these yet?
Discussion Starter #17
OK I got the extreme- vision ones.Installed without taking fairings off.not too hard.well I haven't had a set of HIDs but these are a lot better than stock.now the next question is how long will they last?I will be switching them once every year go try and get a little more life out of them.Does anybody know how to adjust the lights?
Is it more or less like this:
I'm going to swap my bulbs either later tonight or tomorrow - it's way too hot outside right now haha.
That is very similar. You may need to rotate the front wheel in opposite directions. This will help with accesibility.
1 - 20 of 30 Posts
