Even with a Pitbull rear stand, I wouldn't recommend it just because there's always that 1% of chance that things might go really wrong.As tittle indicates; would it be safe to set the bike on a rear stand, and run it through the gears? Any dangers? :what:
Thanks![]()
Maybe you can do it once but not continuously. Generally, there won't be any problem. Even if there is on the road, you can hold in the clutch anytime and that would help.I see your point.
I guess it might just not be worth it then
But I'd still like to try and go through all the gears on a stand.
If there are any problems; I'd like to find them in my garage, not on the road![]()
Good point thanksThe stands is not the weak point the issue is the weld on the spool mount breaking, its more common than your may think
As far as making mistakes, I recommend getting frame sliders as soon as the ones for the 300 are available. The "fits all models Kawasaki" swingarm spools fit the 300, so if you even wanted to just get used to shifting, get a pair of those little critters and get yourself a stand. Prop the back end up, hop on the bike, turn 'er on and practice your shifting! On the aside: the hex keys that come with the bike's tool kit don't fit the universal spools, so if you don't have a separate collection already, you'll need to go pick some up. (I do not kid about shift practice on the stand. I did that with my boyfriend's Jixxer 600. Totally stable and safe.)
No I am refering to the actual point that the spool screws into. There is is that nut welded to the swingarm that the spool screws into. I have seen TONS of threads that talk about the weld on that nut breaking and the bike falling off the stand, from the weight of the bike aloneGood point thanks
High quality sliders/spools would probably be a good idea then![]()
Ill go with my dad who rode motorcycles alot when he was younger...I began to stretch before riding and also adjusted my position on the bike (scooting more towards the front) and the hip soreness has disappeared. Thanks for the recommendations! I was hoping it wasn't and everyday thing.
He.hates.cruisers.if he has back issues a ninja actually may nto be the best bet for him.. because your leaning forward.. the vibrations not bad, but tis not a super cush ride like on other style bikes, they are meant for a sportier feel. aka stiffer in many ways.
Vibrations negligable compared to his old bike for sure, but I would let him test ride a few style bikes before throwing hard earned cash down for one, for his back its prob not the vibration thats to worry its the seating postion he shoudl worry about, thats my opinion, a cruiser is prob the best bet, but its up to him, lol
