I tried searching for threads on this topic but i couldnt find any. I want to remove my tires from the wheel/rim and i just got my front and rear stands. So taking the wheels off the bike will be no problem. Now i want to remove the tire from the rim so i can send in my rim to be powdercoated. Any suggestions as to what tools i should purchase to use for this process? I was looking at bead breaker tools but if i use that to remove the tire, will i be able to use that wheel agan at a later time? "Bead breaker" just sounds permanent lol
Bead breaker, tire lube and 3 tire spoons or irons. Start watching utube vids on tire changing. It is easy once you learn the correct method. A 5g pail makes a decent stand to work on too.
