1 - 13 of 13 Posts
Has anyone has anyone tried these out on the 300? If so, impressions? What other performance mods do/did you have? And has anybody been able to find any Maps for either of these?
My planned setup for spring is a full TBR exhaust, a juice box pro, and a K&N kit. I'm just working on getting it all ordered and want to hear any other opinions and experiences anyone might have.
Like stated, the Autotune allows you to input your own target AFR values. Normally we see best power in the range of 12.8-13.4:1. Best fuel economy, can't say as we don't normally test for it. We have seen cases though that ADDING fuel has increased fuel economy. This was on a bike that was extremely lean. By adding fuel we made each combustion stroke more efficient. Therefore instead of cruising down the highway at 15% throttle to maintain 65mph you now only need 8% throttle. Most people will set their AFR to 14.0-14.2:1 for best economy.
If you are using the map switch WHILE Autotune is enabled the map switch will toggle between a BASE map and the Autotune being active. If you are not using Autotune then the map switch will toggle between 2 completely different saved maps within the PCV.
Hope this helps.
the Auto tune does it build a map over time or does it just modify air/fuel mixture in real time and everytime you turn the bike off it forgets everything it has learnt from the ride?
1 - 13 of 13 Posts
