I just want to say that my particular question doesn't have anything to do directly with the Ninja 300, its more of a general hardware question that may or may not pertain to us 300 owners. I am asking this here because I know there are some engineers and mechanics among us.
My question is, is there a torque limit or suggested range for Phillips head screws/bolts? For example, does a #2 Phillips head bolt have a published or known max torque that should be applied to them. I know they are designed to "cam out", but I haven't seen anything that says what torque a given size screw will do that at. The reason I ask is because I have to on a regular basis torque a countersunk 1/4-28 bolt to 75 in/lbs but with a fairly low success rate. I, and others tend to have about half of the bolts we put in cam out on us requiring them to be replaced and reattempted :(. The bolts are a steel alloy with a #3 Phillips head so its a pretty robust bolt. I end up changing the bit a lot to make sure it is "sharp" and have double checked all of them and the bolt data sheet to make I am using the right size so I know that's not the issue.
Do any of you mechanically inclined people out there have any input? Perhaps point me to a data sheet that tells me that the bolt should be able to do what I am asking of it or possibly the opposite. There are a few avenues I am looking to pursue with this but I want to try and build up some supporting material first before I try to get something changed.
I expect that it would also depend on the hardness of the metal, so I don't think you'll be able to find a general number.
Switch to a Robertson or hex screw to prevent it from caming out as easily. They are much better for high torque situations and are much less likely to strip
Alot of times when torquing phillip or standard head screws/bolts to the higher in/lbs range that its not the torque that is stripping the head, but rather the pressure you put at a downward range not being enough to keep the screwdriver planted in the head of the screw/bolt. Also the angle one holds the screwdriver also makes a big difference. Even tho i've been wrenching for 35+ yrs I will still find myself in a hurry or can't hold the driver in a proper position to keep it seated and end up stripping the driver or the head of the screw/bolt.
Anyway, yes the hardness of the screw/bolt size and angle and number of threads is what determines the actual in/lbs to torque. There are tables out there you can download to tell you the general torque values of sizes and thread angle of most know bolts and screws.
one I just did a yahoo search on
http://www.engineershandbook.com/Tables/torque2.htm
