I saw someone mention sandblasting in another thread and I was curious what is the best way to paint wheels? I'm on the 2016 (red fairings with black wheels). I like the look of the Ducati 959, but can't afford one, so I was thinking of getting an unpainted fairing set, painting that pearl, then painting the wheels red. Looking for advice as I'm not sure the best way to go about painting the wheels. In Roseburg there are powder coating and sandblasting shops and I'm not sure what each of them do exactly, I was just told I might want to sandblast my wheels. I suppose I'll just call and ask, but it's saturday night and they don't open till Monday, so thought I'd seek feedback here. Painting the fairings too. If I buy a white (unpainted) set on ebay, I don't imagine I need any primer - or anything - other than the pearl paint. There's youtube videos of guys using a $15 paint gun from Harbor Freight to paint cars and motorcycles, so I'm thinking of going that route. If any of you have experience in this world, I'd appreciate the insight. I'm a total noob going for broke.
This is what I hope my bike will look like. I might even get a little 300 sticker where the 959 is... if I can find a decent one.
Tire Wheel Fuel tank Automotive tire Automotive lighting
I love the idea! Red wheels would be awesome.
I had wheels for my GSX-R powder coated by a shop here in Seattle, so I can share my story there.
The shops that "do powder coating" usually offer a few services. The right way to get your wheels red is definitely powder coat. But there are steps prior to doing a quality powder coat that you don't want to skip. So any shop you are inquiring to, ask them if they offer:
  • sand blasting (of wheels, since they are large)
  • "chem dip" or similar process to make the wheel metal inert and prevent corrosion
  • and obviously powder coating (and masking if they're a good shop)
I had this process done to my wheels, and they came out perfect. Not only that, but the powder coat finish has proven to be extremely durable against impacts and chemicals. I had a leaky caliper get brake fluid all over the wheel, and even if I left it to dry on the wheel, it didn't damage the finish one bit. It still looks as good as the day I got it, now about 4000 miles later of riding.
When I was getting a quote and discussing the job with the shop, they informed me also that certain colors, finishes, and metallic colors had varying levels of durability. I originally wanted gold wheels in the ducati wheel gold, and they had a nearly identical powder on hand. Although the tech informed me that the gold not only required a second, clear powder coating layer just to get it to "be durable" but also that it may be more susceptible to damage and fade. Bummer. So I went with white. The white powder is apparently a very well formulated color that is both deep, shiny, durable, and overall good for use on a wheel. So make sure the shop has a well formulated red powder in the color you want, and you basically gotta go to the shop in person to see the color swatch sample of the powder to make sure it is what you want. If they are a good shop, they will have a wall of color samples.
And in case it wasn't clear, you must remove absolutely everything from the wheels prior to the coatings. Bearings, spacers, tires, valve stems, wheel weights, cush drive, rim stickers, everything. So you will need to purchase all these items again once the wheel is done and reinstall all of those or have a shop do it. The price adds up pretty quick, so make sure it is what you want.
Hope this helps put this into perspective. Whatever you choose to do, just don't spray paint your wheels. My GSX-R wheels were spray painted by previous owner, and it was awful, so I spent hundreds of dollars to get it removed.
If you want advice on painting fairings as well, I did a write up on the Gixxer forum I could link you to if you want DIY good-quality paint job outcome for cheap, and I'd be happy to share that to help you on the path to making a unique 300!
Sparky gave you some great info to get started...I'll only add that you will definitely need to prime any new plastic fairings you buy. You can DIY a great paint job...but there is a lot of prep work, priming, sanding, color coat, clear coat...not quite as simple as spray and go. Might be worth getting a quote form a shop on a Pro paint job on your fairings.
Discussion Starter · #4 ·
Thanks guys. I'll start making some calls / inquiries Monday to see who can do what and about how much this is all going to take - for the wheels.
As far as the fairings go, I am starting to ask questions now because a neighbor is helping a guy paint a (classic) car - pearl white - and he says he may have enough paint leftover for my bike. I'll ask him about prep/primer/coats, etc. I'm hoping that part of this job will be the least painful and least expensive.
Appreciate it!
If/when I get to that point, I'll post some pics. 😁🧀🏍 varoom
I would suggest making sure the powder coating shop you are considering is well versed in doing cycle wheels. There are details that need to be done that many large production shops don't do - like careful masking of mounting surfaces, openings, and threads. Look for photos of wheels on their website/FB page, and look closely that the rotor mount surfaces are bearing openings are not coated. Make sure you have the rotors and bearings out before heading to the powder coater.
It’s usually most efficient to chemically strip the coating from the wheels instead of blasting. Often the blasting needs to be too aggressive in order to remove the factory coating, and it leaves too much texture on the metal that either needs too much powder to cover or will show through.
Typically, wheels will run from $100 to $150 each in a stock color. Ordering a color usually adds about $30 for the amount required for a set of wheels. Some colors, commonly metallics, require a clear coat which adds 30 to 50% to the base cost, as it requires an additional coating and curing procedure.
When done properly, powder is going to be significantly more durable than paint - even OEM paint.
Jay
www.apexcustomcoating.com
