2.2 liters oil = 2.3 quarts
Fairings on in driveway, busted knuckles, aluminum foil to keep oil off exhaust when removing filter:
Fairings on in shop on MC lift, oil change without jackstand, coolant, chain lube n adjust (but should use alignment tool), charge and jump battery, OD on carbon monoxide:
Right side lower fairing removed in garage, torque oil drain plug 14.5 ft lbs:
How to remove all engine fairings, sammich bag for loose parts, take photos of bolts and parts before removal:
How to safety wire oil filter, drain bolt and filler cap, using a hose clamp, optional predrilled drain bolt:
Gadgets to make safety wire fun with less profanity:
How to train your GF to change your oil and make you a sammich:
Skip the motorcycle technician school... or don't. This is how I became a mechanic without any school.If you want to know how to become a motorcycle mechanic...
youtu.be
As a home learned dabbling mechanic I know how intimidating getting started on bike maintenance can be. However, doing our own work on the bikes can be in ev...
youtu.be
-Watch My Previous Video: http://bit.ly/InstagramCops---------------All My Social Media Links:-Twitter: http://www.twitter.com/JoshLeyva-Instagram: http://ww...
youtu.be
WARNING: If you have a new bike pay the dealer to do it to remain in warrantee
