How does one calculate the frequency interval for higher odometer readings going off the owner manual's Periodic Maintenance Chart below?
I find the "normal" recommended change intervals extremely high for a 2.2L oil capacity engine, especially since my other ride, a 2002 Suzuki SV650S gen1, has the same recommended oil change intervals but is nowhere close to constantly running in high rpms and has a larger ~3.0L oil capacity.
I ride the ninja 300 as a daily (currently clocked up 67,000 kms) and due to its small engine capacity, it's ridden to its limits (high rev range) on and off the freeway.
I've had a couple mechanics recommend I be changing the oil every 4,000 kms due to my riding style.
So back to my initial question, how does one calculate the frequency interval for higher odometer readings going off the owner manual's Periodic Maintenance Chart? I couldn't really make sense of it.
And those of you who do ride the ninja 300 as a daily, what intervals do you change at? And have you needed to top up on oil before an oil change before that? (I changed every 5,000 kms with minimal top up required before change)
First oil change | @ | 600 miles | 1,000 kms | ||
Second oil change | @ | 7,600 miles | 12,200 kms | ||
Third oil change | @ | 15,200 miles | 24,400 kms | ||
Consecutive oil changes | @ | Every 7,600 miles | 12,200 kms | or | Every 1 year |
