why 20w50?? book calls for 10w40...no flakes i could see in this oil change. i am running standard kawasaki 20w50 right now until the next oil change i will start running synthetic
Some oil hits the pipe when you pull the filter, even if you're using a rear stand or center stand.Does any oil hit your pipes or plastic when you pull the filter?
