I've only ever checked and adjusted the tappet/lock nut type valves so I don't think the method I used with the feeler gauges works the same with the valve buckets.
I have always pushed the feeler gauge even if it takes a bit of force, and then slide it back and forth and see how much resistance it has to sliding between the valve and the tappet.
For instance, I can try a .23mm and it goes easy and feels too loose, so then try .25 and it goes in nice and when I slide it back and forth and feels perfect. Then I try the .28mm and it hits a slight stop but I can still get the gauge in by pushing on it and when I slide it back and forth it feels exactly the same as the .25mm??
I think I'm doing it wrong. I'm guessing that if the gauges stops at all then it is too big and my clearance is the next size down? It's hard to explain what I mean but I am wondering how you guys check your clearances? Do you go by the force it takes to push the gauge in or how well it slides back and forth once it's between the valve and bucket?
I also read somewhere that the Ninja 300's valve buckets have a slight concave to them that will allow you to insert a gauge that is actually too large?
So, if the gauge stops at all when trying to insert it then it's too big even if I can push it in with slight force?
It is driving me nuts and I've checked the valves 100 times but I don't want to button everything back up until I know my clearances are correct.
