1 - 10 of 10 Posts
Put a new rear fender on yesterday, started up the bike afterwards and all was well. Today, I turn the key and nothing happens. I've pulled the seat, cleaned the terminals, charged the battery fully (it wasn't dead), checked all the fuses. Nothing gives, I did have some contact with the kickstand as I pulled it off the lift table (oops), but that sensor won't kill everything, right?
Discussion Starter · #4 ·
I think that's right on the kickstand, and checked the fuses to the other responder.
Not exactly sure of the KICK STAND SENSOR circuitry, but under the certain conditions I believe it will kill everything. :surprise:
Once some of our forum mechanics sign on and see this posting they will be able to give a good explanation of the circuitry. :wink2:
Sorry, I could not give you a more definite reply. :frown2:
i have the same problem turn key on power anywhere and as soon as i put the 2 fuses in the starter relay they blow
Something is hooked up backwards or there is a wire/connection going right to ground.
Check the wiring carefully. Might be possible that the relay is bad.
I checked the main fuse and all the little extra fuses. When I turn the key no lights come on. When turning the key to the on and off positions I can hear a click sound from under the tank near the main fuse (but isn’t the main fuse). I have no mechanic brains at all. I need help and am in AK lol! The season is too short for this crap :(
1 - 10 of 10 Posts
