1 - 2 of 2 Posts
Is it possible for the ninja 300 to use the ninja 400 speedometer. I really like the design of it tho. Or if you need any modifications in the wiring for it to work?
Dashes are usually designed to work with the exact bike theyre on....
The first problem is that the engine in the 400 is different, and has a different redline, and so the tach would not function correctly I'd say.
The latest model 300 and older ones have a different dash appearance though, and they are likely interchangeable. I have the older style, and I do like the look of the newer style, but IMO it's not worth the trouble of changing.
Also, I believe instrument clusters are quite expensive, especially since you cannot reset the miles on a used dash. Then it would just read wrong all the time, a loss for you and any future owners IMO.
I would leave it if I was you, but if you really want to tear up the front end, would be a rad project to see.
1 - 2 of 2 Posts
