1 - 4 of 4 Posts
Hello. Im having an issue with my bike not accelerating properly. Out of no where when I was accelerating, I loss a bit of power but it was reving high with lower rpms. I've clean the air filter on it and adjusted the throttle by the throttle handle. Any ideas?
Oil level OK?
How old is the gas?
Check that your battery is good. Should be over 12.7V before starting.
Are the RPMs climbing, but the cycle is not accelerating? That would suggest a clutch issue.
I figured out what might be the issue. The clutch is not fully released or might have a slight stick to it. Anyway to adjust this? Also, clutch seem right when I try to pull it with my ring finger.
1 - 4 of 4 Posts
