41 - 60 of 87 Posts
OEM Air Filter Replacements for the Ninja 300
This is a list of available air filters for the Ninja 300. Theses filters also fit the '08-'12 Ninja 250R. This may not be an exhaustive list. Feel free to post others that you may know of or use.
OEM Kawasaki Air Filter- Kawasaki P/N: 11013-0020
WIX- P/N: 49721
This is a Dual Stage foam filter. [1]
K&N Air Filter- P/N: KA-2508
K&N Stock Replacement Air Filters allow engines to breath more efficiently, and are the first step to getting more horsepower from your bike. These filters use pleated, multi-layer surgical cotton mesh to deliver the best air cleaning qualities and the highest air flow rate. No rejetting is required with a stock muffler
BMC Air Filter - P/N: BMC-FM551-04
BMC air filters are designed and produced to ensure a higher air flow than original paper filters. BMC air filters, made in cotton, minimize the loss of air flow pressure passing through the air filter; this way ensures the best conditions for full exploitation of maximum power. Therefore, the benefits of replacing the original paper filter with a BMC cotton air filter in your motorcycles are evident.
JFC Performance Filter
Sportisi Motorsport is the EXCLUSIVE sole distributor for JFC Drop in air filter for the NINJA 250R. This product is an instant PERFORMANCE INCREASE without any jetting changes required on a standard bike.
UNI Air Filter- P/N: NU-2303 [2]
•Higher airflow for higher performance •Fits in stock airbox exactly like OEM filter •Longer service intervals •Cleans easily with grease-cutting dishwashing detergent; just clean, re-oil and reuse indefinitely •Stop more dirt than paper filters
DNA Air Filter- P/N: P-K6S07-0R
This new DNA filter is designed to replace the stock foam filter without any modifications. This DNA filter features a very large filtering area, combined with 4 layers of High quality DNA Surgical nafta cotton, impregnated in DNA Special air filter oil.
Pipercross Performance Air Filter- P/N: MXP166
Pipercross foam is the secret to a lightweight, long life performance air filter. Pipercross air filters consistently outperform paper and cotton-gauze rivals to supply air to the engine - even when dirty. This is thanks to the multi-laminate construction used in every Pipercross performance air filter. Layers of varying porosity foam all work together to trap different sized particles. Pipercross have developed the perfect combination of filter density and thickness of each layer. Where Pipercross filters are impregnated with the dirt retention additive, the filtration performance is greater enhanced - the additive helps the foam to swell, opening pores whilst providing a "sticky" layer to hold more dirt.
Hurricane Racing Performance Air Filter - P/N: HM-8106
This filter is made from high grade SUS-304 steel mesh. It has the advantage over cotton as being less tedious to maintain; it can be washed, blow dried and replaced without the need of any specialist products or oiling. See the review and pics of this filter. [3]
Hurricane Racing Performance Air Filter - P/N: HC-8106
This filter uses a double layered cotton fabric as a filter medium. "Our Cotton Gauze Filters are available in a range of colors and in all shapes and sizes. They are made using the same rubber frames and patented construction as our Stainless Steel filters, so quality and performance are assured. A very cost effective filter. They also offer the same benefits as our Stainless Steel Filters, but do require a little more care when cleaning, including re-oiling using Hurricane's Air Filter Cleaner and Oil." [4]
I know oem rearsets are interchangable, so would your best bet be that aftermarker rearsets are too?
vortex has a backorder of ninja 300 rearsets but have plenty of stock from the 250r.
Yeah cheers Bluez!
I thought as much but I did have some doubts.
Dna
Hi, I went to change air filter in my 2 months old ninja 300, as i thought it sucked oil.
Dealer had KN, BMC and DNA
DNA was cheapest
KN and BMC well overpriced in thailand like over 100USD
so price decided for me
went for DNA was like 2000 thai bath compare to 3500 others (xe.com)
DNA looks preety same as KN, good quality, difference its oil filter like BMC
Bike feels much better
better responsive, better torque, no chocking...
I can recommend DNA
didnt notice difference in sound
THX
WIX- P/N: 49721
Grips are universal. Any online bike retailer will have them. Revzilla, stg, hard racing.
you forgot one small "got ya"
there is some that are designed for cruisers , most cruisers have a different size then sports bikes / sport tourers etc
the 7/8 is usually the one for sports bikes and the likes
I may have missed it, but are the mirrors the same between the 2013 Ninja 300 and the 250R
If not, what are the specs/information I need to buy a new set?
41 - 60 of 87 Posts
