Hey folks, in need of some smart ideas...
I was doing a routine replacement of a coolant pipe and rubber bushings/dampers for it, no big deal. Had all the pieces ready, and I started getting in there and drained the coolant, all was well.
Here's where this all took a massive turn for the worse. So the hard coolant line that comes off the cylinder head (39192-0131) has two rubber bushings that hold it in place, clamped under the cylinder head cover. I have these two rubber piece as well, so I was going to put them all in, along with a new O-ring on the pipe. Great plan.
Well, I am so stupid. I forgot to cover the coolant channel on the cylinder head where the pipe goes, and I managed to drop the rubber piece (92161-0690) inside the cylinder head coolant output channel. It is just small enough to fit down inside that hole, and make the sharp 90 degree turn into the cylinder head water jacket. Cue unbelievable anger and profanity, and 6 hours of depressing inability to remove the piece. I cannot see it anymore. There is a small chance the piece is not actually inside my engine, and fell onto the floor somewhere, but I am 95% sure it is in there. Floor is clean.
The piece is rubber, so magnets won't work. The piece sinks in water, I checked with a similar piece, so I can't float it out.
The nice thing I guess is if I leave it in there, the piece of rubber cannot get to the water pump, since the water jacket and head gasket channels are too thin, and obviously the piece won't get through the thermostat or radiator fins. The piece is also designed to be on the cylinder head, so it won't melt. So at least the piece won't cause catastrophic damage if I leave it in, but I don't want it to get stuck on or in the thermostat should it make it there. So if I have to leave it in there until I get the parts to remove the cylinder head and all the other methods of removal fail, I may have to devise a mesh or filter of sorts right before the thermostat to prevent damage.
Super ultra frustrating. Track day this upcoming Saturday, and this repair to fix a leak and clogged radiator should have taken a few hours, and now it is at best going to be a few days of trying to fish out this stupid bushing...
Any bright ideas? I'm just so frustrated this happened. What a terrible way to mess up a simple repair.
- Tried compressed canned air to blow the piece out of the coolant channel, no dice.
- If I can find someone with a powerful air compressor, gonna try that.
- If that fails, going to try using a household vacuum cleaner, maybe paired with a mesh screen to prevent the piece from being sucked into the canister.
- If that fails, probably going to find a random clear rubber hose from a hardware store and route it around the thermostat, and try running the engine filled with distilled water, and see if the coolant flow will push the piece to the radiator where I can just shake it out. The clear hose would let me see it flow to the radiator, and prevent it from getting stuck in the thermostat.
- If that fails, I will have to remove the cylinder head to fish it out, and replace the head gasket and studs and washers. Really do not want to do that.
