1 - 7 of 7 Posts
its just braking in.. whats even better smell that smoke.. its the smell of pure awesomeness :D
I have the full system so not sure about the wobble, you could give them a call, they have great customer service.
The smoke is normal. It burns off and breaks in and gets a little quieter after a while. The clamp you need a wrench. You won't get it tight enough with just the Allen key. I actually had the torque wrench out and torqued it to 15ft lbs. Also that anti-lock you put in between the pipes lets it move. It will burn off eventually.
1 - 7 of 7 Posts
