1 - 16 of 16 Posts
Hey all,
So I went on my first touring ride with a group! It was about 200 miles each way, after the first hour OW that stock seat is just agony!
Any luck with the Saddlemen gel-channel seats, or corbin seats? Looks like the reviews for Saddlemen seats are a bit mixed.
Would like to know the same.
Haven't attempted a LONG ride yet, for exactly this [sore butt] reason.
To start, their is not going to be much padding on a seat for a NINJA. But, I have done some reading / research on both Saddleman and Corbin. I think that if I was making a choice right now, I would most likely opt for the Saddleman. One reason being is that the shape is somewhat different. Different in a way that it provides more area for your butt cheeks. :laugh2: And the front of the seat is angled differently than a stock seat as it provides some resistance from sliding forward into the gas tank.
With that said, I opted for and installed the " Kawasaki Factory GEL Seat " on my NINJA. Only have about 300 miles on it and can not provide a full review. But it is somewhat more comfortable than the stock seat and after a period of time it does seem to be taking the shape of your butt.
One thing you do have to take into account as with the factory GEL seat, it is " ONE " inch thicker than the stock seat. Not that you will notice it because you are sitting more into the seat, but you are sitting higher and thus you are reaching more forward for the handle bars. And if you are on the short side with a short inseam, you will be reaching further to touch the ground.
As for comfort rides on the NINJA, " PERSONALLY " I feel that a 100 mile break and stretch is a requirement. It seemed to work for me when I had the stock seat and I am still doing so with the GEL seat.
But in closing, I think that if I had to do it all over again, I may have opted for the Saddleman seat. But before you opt for it, their is one other thing I would check out and that is the PASSENGER PAD. The factory seat comes with a new full GEL matching passenger pad, while I think some of the other seats mentioned only come with a passenger pad cover.
Just do your homework and good luck.
P.S. If you are looking for real comfort, then buy a Honda Gold Wing :excl::excl::signlol:
You can also install you own gel pad in your seat. I've done it on a few bikes now and it makes a pretty big difference.
Thanks for the reply, I'm not looking to turn my 300 into a Gold Wing (or get one), just for some relief on 2+ hour rides. I may have my local chopper shop just rebuild the seat with some memory foam, he's quite reasonable.
Cheers!
Discussion Starter #8 (Edited)
Quote from a customer on Cyclegear regarding the Saddlemen Gel-Channel Sport Seat at standard height (the tallest one)
"I got the standard one and the height feels about 1/4 inch higher than the OEM seat. Not a huge difference."
I doubt 1/4" will make much of a difference, the Kawasaki Gel seat is 5/8" taller, so the manufacturer claims, and includes the passenger seat.
Review for the Saddlemen 'TECH' seat
"The seat raises the seat height by 1.5 inches or so. It is super comfortable for the nice long rides from Las Vegas to Salt Lake. The seat does get damaged by the sun easily and fades to a gray. It will then start deteriorating and will look super shaggy.
I probably wouldn't buy it again for the price of it."
-note, it does include a protective cover, doesn't sound like this customer bothered to use it.
The Saddlemen Gel-channeled Tech (not sport) seat is designed for maximum comfort and long rides.
Saddlemen: $280-$290
Kawa Gel seat + passenger seat: $360
GEL SEAT UPDATE to previous posting :
Took a ride this afternoon on just basically country roads. But stayed on the bike for over TWO hours.
Will have to admit and report that the " factory " GEL seat seems to be starting to work for me. What I mean is that other riders have reported that you need to give a GEL seat time to work and take shape. What I mean by taking shape is forming to your own body.
My other rides were basically one hour in duration, but today I wanted to push the envelope a bit and stretched it out to a little over two hours. I am quite sure that I could have ridden longer, but had other things on my agenda and had to return home.
I am starting to believe that an all day ride would not be a problem. Naturally you would have to take some rest time, but you could also push the time in the saddle. Also, you may have to stop for gas. :laugh2:
Even though in some people's minds it is a little costly, I now firmly believe that the " Kawasaki GEL Seat " was the right choice choice, at least for this Ninja 300 rider.
It mean buying a gel pad, removing your seat cover, carving out a spot for the gel pad in the foam, installing it, covering it with a layer of smoothing foam and then restapling your stick cover on. It sounds complicated but there are tutorials online and if you take your time the seat can look stock, be a lot more comfortable and the whole thing costs $60
Discussion Starter #11
I'm ordering the Saddlemen Tech seat, I'll update this thread and we can compare.
I have the saddlemen and it took me from 1/2 hr rides to an hour and a half and beyond. Seat, exhaust, fender eliminated. Getting a steering damper and then this bike is done. But the seat is worth the money.
Kawasaki Factory GEL seat took me from one hour ride to beyond two hour rides.
Can now only assume that the GEL works. :smile2:
By the way (not sure if this is already mentioned in THIS thread), but there was a suggestion previously (by rogue, maybe?) to use padded BICYCLE shorts, instead of modifying the stock Kawasaki seat.
I am probably going to try this for an upcoming trip, about 350 miles each way (longest for me on the Ninja 300 so far).
If all else fails, perhaps DEPENDS may help. :signlol:
Guilty as charged!
1 - 16 of 16 Posts
