1 - 15 of 15 Posts
Hello I just got my ninja a little over a week ago and have no issues with the machine except for this small cosmetic flaw.
My plastic piece directly under seat, ( inner thigh contacts this piece while standing) which on my se is black is loose on the end of the piece nearest the plate. I know that's a lot to soak in but any help/input is appreciated.
As a note: the opposite side is well tight
Awesome
Im truly very appreciative of the input. The dealer charged mine so I suspect it fell out then. A rubber bushing truly makes sense b/c the other side seems soft and has minimal play when pushed on. The loose side seems hollow.
I hope dealer will have an oem in stock
Thanks everyone very helpful!!!
I'm going to pull it apart tomorrow and compare w/ your pics to see which one I'm missing. My guess is the bushing closest the taillight.
Pictures very helpful thanks again!! Very relieved not something I must deal with forever.
Be carful the ones up front like to pull out also u can see the one and the hole missing one to the right almost out of sight it came off for the pic.
Discussion Starter #9
Thanks again and ill be sure to search next time instead of immediately posting whatever the question is. Should have known I'm not the first with the issue.
I can't believe how much info is on this forum It's truly an invaluable resource.
Discussion Starter #13
Dealer and I are going to pull one off a 300 he has in stock. I hate to do that but I need it bad lol, I'm just glad he's going to make it right
That fairing piece is one that seems to be an issue from the factory in regards to it being warped. My bike had the same issue, along with a nice little thumb print on the large side fairing, and I checked all the other 300's as the dealer got them in and they all had that issue to some degree or another. I'm glad that your dealer has helped you with this issue, and I was going to say if they don't then definitely contact Kawi directly and they will take care of the issue.
1 - 15 of 15 Posts
