1 - 3 of 3 Posts
I was going 95 in the fast lane last month when my engine started losing power. All lights stayed on, but power just started going away and I had to pull out on the fast lane median. Installed a brand new battery in it, solenoid clicks, does not turn whatsoever. Got it towed to the dealership, was told the starter is fried and they'd need to order and install a new one before they can even fully troubleshoot the engine, and it would be over $500. A buddy of mine knows bikes and engines really well and offered to rebuild the engine for/with me at his place, so I'm going to get it towed there and we're going to make a project out of it. He told me to start looking around for a big bore kit or some kind of engine performance kit that includes pistons, cylinders and/or crank, look for a crashed one or an engine for sale. I'll throw the money at it for parts to rebuild it ourselves, because I know jack shit about engines and I figure this will be the best way for me to gain some valuable knowledge in this area
Are you sure the engine is toasted and it's not just the electrical problem? Does the engine spin with the starter motor?
A take off stator on eBay will cost you about $100
It looks like it's common for 2013's to burn the stator early. Mine did some months ago at 14k miles,
Did it have oil in it when it quit? If so, it would be odd for the engine to seize or lock-up.
Remove the round plug on the left engine sidecover (stator) and spin the engine over by hand with a socket/ratchet, or put it in a high gear and see if you can push it while turning over the engine.
I wouldn't start taking things apart until you are absolutely certain the engine is locked up.
If it appears to be seized, drain the oil and look for bronze-colored flakes. If it ran out of oil and the rod bearings are toast you will see burnt bearing material in the oil.
1 - 3 of 3 Posts
