Kawasaki Ninja 300 Specifications
ENGINE
DRIVETRAIN
FRAME
SUSPENSION
Suspension, Front 37mm telescopic fork
Suspension, Rear Bottom-Link Uni-Trak with gas charged shock and 5-way adjustable preload
BRAKES
DIMENSIONS
PERFORMANCE
DETAILS
ENGINE
- Type 4-stroke Parallel Twin
- Displacement 296cc
- Bore and Stroke 62.0 x 49.0 mm
- Cooling Liquid-cooled
- Compression Ratio 10.6:1
- Valve System DOHC, 8 valves
- Fuel System Fuel Injection: 32mm x 2 (Keihin)
- Ignition Digital
- Lubrication Forced Lubrication, wet sump
DRIVETRAIN
- Transmission 6-speed, return
- Final Drive Seeled chain
- Primary Reduction Ratio 3.087 (71/23)
- Gear Ratio: 1st 2.714 (38/14)
- Gear Ratio: 2nd 1.789 (34/19)
- Gear Ratio: 3rd 1.409 (31/22)
- Gear Ratio: 4th 1.160 (29/25)
- Gear Ratio: 5th 1.000 (27/27)
- Gear Ratio: 6th .857 (24/28)
- Final Reduction Ratio 3.000 (42/14)
- Clutch Wet multi-disc, manual
FRAME
- Type Tube diamond,steel
- Wheel Travel: Front 120mm
- Tire: Front 110/70-17 M/C 54S
- Wheel Travel: Rear 132mm
- Tire: Rear 140/70-17 M/C 66S
- Caster (Rake) 27°
- Trail 93mm
- Steering Angle (Left/Right) 35° / 35°
SUSPENSION
BRAKES
- Front: Type Single 290 mm petal disc
- Front: Calipers Single balanced actuation dual-piston
- Rear: Type Single 220mm petal disc
- Rear: Calipers Dual-piston
DIMENSIONS
- Overall Length 2,015mm
- Overall Width 715mm
- Overall Height 1,110mm
- Wheelbase 1,405mm
- Ground Clearance 140mm
- Seat Height 785mm
- Curb Mass** 172kg
- Fuel Capacity 17 litres ** Includes all necessary materials and fluids to operate correctly, full tank of fuel (more than 90% of capacity) and tool kit (if supplied)
PERFORMANCE
- Maximum Power‡ 29.0 kW {39PS} / 11,000
- Maximum Torque‡ 27.0 N·m {2.8 kgf·m} / 10,000 rpm ‡ Power / Torque figures measured at the crankshaft.
DETAILS
- Warranty 12 months warranty
