Do you all think that the universal kit is the way to go or will there eventually be a 300 specific kit coming out?
For me, I it seems like the LED blinkers do not draw enough power. My turn signals do not blink properly with them. If I connect up the stock, it's fine. I might splice in some resistors to increase the load.This is the kit off of eBay :
http://item.mobileweb.ebay.com/viewitem?itemId=330450090034
Tools you need:
Bike screw driver, wire splicing tool, and electric tape.
You have to:
Remove the stock fender
Bend the eBay kit bracket to fit perfect under tail.
Cut the wires from the stock blinkers (about 8 inches)and cut the tail light blinker wire off (you don't need it; the kit comes with led plate light)
Screw the stock blinkers or the ones that come with it to the plate attach wires ( twist them together )
Put electrical tape around twists clean it up and tuck neatly away behind plate.
I wish I took pictures step by step
But if you do decide to get this kit I will walk you through it but its fairly simple. I am not a handy guy and I put it together.
Sent from my iPhone using MO Free
Can you post the link to the ebay seller? I'm keen to keep the stock electrics.View attachment 34 View attachment 35
Just finished install. I found a kit off of eBay, and just used the stock blinkers. It's a very clean look!
Nope it just clicked on and stayed on.Is it flashing quickly? That's hyperflashing. Resistors work or a flash relay.
