Hey folks. Just joined the forum, but I’ve been lurking for a while doing research on the 300. Want to thank all of you for providing such great info on these bikes.
I finally pulled the trigger on a beat up 2015 to use as a track-only bike. It’s rough, but I’m ok with that - since it gives me an opportunity to get to know the entire bike.
Cleaned up some electrics and replaced the steering stem ball bearings with tapered bearings. Everything went well.
But now it’s looking like I need a head gasket replacement.
The oil was classic milk colored. I flushed with fresh oil until it flowed clean(ish). Filled again with fresh oil but after running it for just a minute, the oil was completely emulsified again. Cold start with the coolant cap removed produced a geyser. When I removed the spark plugs there was moisture in the right cylinder, which spit out while turning the engine over. Think it was just water. So there is definitely gasses getting into the coolant system.
Best I can tell, all the tests point toward the head gasket being blown (or worse???). If anyone has any other tests I should try, please chime in.
I would like to make sure I have everything I need for the replacement. I have the shop manual, and will order OEM head gasket and exhaust gaskets. Are there any other gaskets/o-rings etc that should be ordered before I start?
I read a post stating that while doing the head gasket it’s required to lap the mating surfaces. Is this the consensus (I think he was talking about an ex500)? Or can the lower half be left on the motor? If I have to remove the lower from the crank case, I guess I’d need that gasket as well
I apologize for the long 1st post.
Any other tips and tricks are welcome.
Thanks!
scott
Thanks!
scott
