1 - 4 of 4 Posts
Hey guys,
So I just bought a 2014 Ninja 300 SE and I'm having some issues with the headlight and wanted to see if anyone else has experienced this.
The headlights do not come on sometimes after starting the engine. I've tried isolating the issue by waiting like 10 seconds for the motor to prime and the gauge cluster to fully initialize and it still is intermittent. Does this sound like a bad relay box? The fuses are good and I've double checked my battery to make sure the ground is fine.
I assume you've checked the bulbs?
What happens if you turn on the bright?
& I assume you know, but only 1 light comes on on the ninja. The other is the bright/high beam.
Does it have a flasher relay somewhere inline?
Headlight fluid must be low!....Duh!...
Or faulty bulb or loose connection if it goes on sometimes....
Discussion Starter #4
Just to close out the thread....
Ended up being a bad reg/rec! Stator was also bad but research led me to the R/R.
1 - 4 of 4 Posts
