1 - 18 of 18 Posts
Did anyone purchase a 300 with a helmet cable to hang your helmet? Mine was missing and I asked the shop they said the lower models did not come with one? Weird because Honda cbr 250 came stock with one.
Also any know where one can get one, or an alternative?
Under the rear seat is a little hook you can put your helmet buckes through and lock your seat down on top of the strap, does it to mine really easily, seems secure
Is that what your looking for?
Not exactly, its an actual cable with loops at the end of each of them. You hook one end of the cable to that hook your referring to then run one end of the wire through your helmet straps and hook the other end of the cable to the same hook, then lock the seat.
The owner's manual shows this. But I couldn't find mine too...
Sent from my Motorola PT550 using Motorcycle.com Android app
The cable gives you a little more room to latch your helmet D rings. If you have the solo seat cowl for instance, you will find it easier to mount your helmet to the cable and hook underneath. I know my Scorpion helmets have very short D ring straps and this cable will make it much simpler to hook to the bike.
I bought this one:
http://www.ebay.com/itm/2010-Honda-N...048213&vxp=mtr
I bought this one:
Item has been removed. Can you post a similar one?
Does anyone have the real name to these?
they are called
the metal cable loopy hooky helmety hanger-on-er-er dovver-bob
or just
tmclhhhd
for short;)
let see if you can say
10 times really fast
1 - 18 of 18 Posts
