1 - 4 of 4 Posts
Should I wait until I get the area p tuner or will I be okay with decatting the header. only other mod is LV slip on
If you decat you essentially have a full system, I would probably get a tuner. You will be ok running for a while, but it will create a lean running condition which isnt favorable really. Nothing drastic that will chernobyl your motor, but I would get a tuner sooner than later if you plan to decat.
absolutely grab a tuner as your now removing back pressure as well therefore creating a flat spot in your power
1 - 4 of 4 Posts
