Use motorcycle oil, do NOT use normal oil you would put in cars. You can find this at any place that sells motorcycles. Some have found it at auto parts stores.. but not near me for some reason, they just dont seem to carry it..? You have to use motorcycle oil due to the wet clutch. if you use regular oil, you will burn your clutch.
Use nothing lower than 87 octane if your in the US, and if your outside the US use 91 octane. Whatever your "regular" gas is where you live. But for sure, nothing below 87.
The owners manual says 87 octane, due to lower compression ratio's.
