1 - 11 of 11 Posts
Hello all,
I am wondering if there is any function (or usage) for the gap between the instrument and the glass as you can see in the following photo
Any opinion???
Don't think there was any plan for that space but a good idea would be to try and move the cluster up into that space to give clearance for driven clip ons. Many people seem to have issues with the cables hitting.
Space also looks good for small add ons
stuff something small in those cubbies!
Aerodynamics. Its one of the first bikes to feature andvanced aerodynamics for rider comfort. I remember reading it on a review.
Its both aerodynamics and cosmetic. It gives flow for air to pass through and also a "flashy" hi speed agressive look to it. Also helps with heat dissipation from the headlight. personally I like the look of the cluster panel and if kawasaki engineers put it on it has to do give a benefit. Possibly helps with the negative pressure on the rider? Like vents do on a windscreen. Would be interesting to see what could fit in there only visible to the ride.
1 - 11 of 11 Posts
