Hey all, so I have a problem with my fuel pump. I have put in a new pump and checked that it works by powering it directly from the battery, how ever when I plug it into the harness it doesn't power. The strange thing is I have checked the voltage at the harness and its good at around 11.8V but when you plug the pump in to the harness it goes down to almost nothing like 138mV. I was able to power it by "hot wire" using a test lead with just the power wire from the harness to the power lead on the plug and it worked fine, but plug the whole thing in and it wont work, any idea why it would do this, I have check the all of the usual suspects (kickstand/tip over sensor/kill switch/clutch lever) any clues I'm at a loss?
