1 - 7 of 7 Posts
Hello there, first time visitor here and I have a question about putting on frame slider.
So I have a 2016 Ninja 300 and I was trying to install a pair of frame sliders. The fair removing went well then I got stuck at the two stubborn bolts (see photos) which not budge at all despite how hard I tried, I even snapped a ratchet extension bar.
Would really appreciate any suggestions.
115133
115134
not sure which bolt you're trying to remove..but I guess the standard answer would be to try an impact wrench..
(assume you've tried a breaker bar as opposed to just putting an extension on a regular ratchet handle?)
Those are two of the five (I think) engine mounting bolts. They get tighten at 50ft-lbs I believe, so a breaker bar should do it.
It may help to put a jack under the engine and put a bit of pressure on it so the bolts won't be bearing the weight of the engine.
You may also want to try and use a good quality 6-point socket, not a 12-point one.
If everything that has been suggested fails (unlikely), you may have to drill the head out.
thanks mate for your help. I think Topaz
Thanks for the advice. Topaz is spot on about the bolt.
Thanks so much for the advice mate. I’ll be putting one in my shopping cart in a moment : ). Cheers
Thank you for reminding. Yes we do have to prevent using 12 point in any situation like this one, it will make it worse!
1 - 7 of 7 Posts
