1 - 3 of 3 Posts
I have a couple of ex300’s and one of them recently started showing no speedometer or anything just the signals, checked the harness and the fuses and they weren't blown, took the fuse out and put it back in while the bike was on and it showed the dashboard working, but when I turned it off and then turn it back on (not the point of where it starts just were it gives power) the dashboard doesnt work again.
Automotive tire Blue Hood Automotive design Motor vehicle
Maybe a connector is bad or connection/ground is failing?
How's the battery voltage? Does it crank when you hit the button?
^^ What he said.
The cluster is the first thing to do funny things when the battery goes wrong. Check the battery first, then the cluster connector. If everything is good. you should start testing the cluster itself.
1 - 3 of 3 Posts
